I bought this older Giotto(2000?but not used regularly ) from a woman who was having a problem with it and sent it out to be fixed. They ordered a new brain for it but didnt solve the problem. She decided to upgrade to a dbl. boiler. She sold it to me for a cheap price with the old brain reinstalled and the new brain also. I started the machine,open the steam valve and the pump came on and filled boiler and then the pump shut off as it should. The pressure came up to proper level. Steam came out of properly. Pulled lever and water came out of group to warm cup. Locked in a test shot and pulled lever and everything worked fine. Then the pressure was not coming back up on the gauge and when I tried to pull the lever on again nothing was happening, pump did not come on. Unplugged the machine and about an hour later plug back in and it started working ok again. Pump came on to fill and pump came on when lever pulled. Any thoughts? My regular machine is a Cremina lever and the is my first e61 machine.
thanks,
Ed
thanks,
Ed
