Machine reccomendation 1K +
  • Machine reccomendation 1K +
    Hi guys,
    really starting to get into this coffee thing. At the moment I have a Krups machine thats about 4 years old and a Delonghi Blade grinder. Not the flashiest combo. Grinding some nice beans from coffeebasics. The coffees nice but I know I can do better. Was all set to go for the silvia but then Ive been reading that its not so good when you are entertaining or want to do more than say 2 lattes so it kind of wont meet my needs.
    Im not loaded with cash and i certainly cant afford a BMW or Mercedes, but when it comes to coffee machines Id like to get the best that I can afford. I think a nice good quality coffee machine and grinder are within my reach. I want something that looks good and is fairly easy to get a decent espresso out of (ie with fresh beans and the right grind). I was budgeting say up to 3 grand for both...
    I actually like the look of those elektra models with the eagle on top, have no idea whether they are a good/functional machine however.
    The Isomacs look great as do some of the Vibiemme machines. Any suggestions would be appreciated.
    Re: Machine reccomendation 1K +
    Originally posted by 2E3F2C242A29202F4D0 link=1241427441/0#0 date=1241427441
    Hi guys,
    Hi Craig and welcome.
    Might I suggest that you nominate a budget for your machine and the grinder youll need? This will allow CSers to help you in your search Are we talking $1k or $4k??
    My thoughts are that you will need to look at the Sunbeam 6910 or something better if youd like steam on tap
    Happy shopping..
    2mcm
      Hi Craig
      I see from your heading that you want a machine for around 1K
      Have a look at this machine combo from sponsors Coffee Machine Express
      Nemox Dell Opera @ $799
      http://coffeemachine.com.au/nemox-dell-opera-p-106.html?osCsid=be1c279148a810a1bc5961bee19f0458
      Good solid machine and you get to spend the rest of the budget on some good fresh coffee beans
        Hi Craig - just as an idea, if you arent fussed on looks, a decent setup with hx machine and good conical burr grinder can be done a fair bit under 2k - expobar office + an iberital/lux or lelit grinder.
        At 3k - well the choices are near endless
          Thanks guys for the fast replies, I actually have considered something such as the Sunbeam 6910, looked at it in the shops, seems solidly built, but ive never had any good experiences as far as sunbeam and breville reliability go... A bit concerned about that aspect as I live in country vic, but then I guess any purchase you can get a lemon.
          At the moment lattes are made by making the espreso shot, and heating the milk in the Microwave. Not the most elegant solution... Mind you did have a Nespresso machine at one point as well but I found all the coffees from that bitter.
          Budget, well I can go up to say 3K for the grinder and machine. I would be after something reliable, and I figure if Im going to aim to spend up to that amount I would be able to get something that is quality and going to last and produce a great coffee. By entertaining say... the machine should have nough grunt to prepare say 5 or 6 milk based coffees... (Im not running a cafe )
          As mentioned I was all set to go the Silvia / Rocky combo, seems like a great machine however Ive read that you can only steam enough milk for say 2 coffees at a time... and thatd be great for me and the other half but no so great when guests pop around....
            I would suggest you could do much better than the Siliva and or 6910 and still get change from 3K..
            Use the sponsor link and contact them.. A few specials going at the moment and some great buys..
              I was set to go the same route - silvia & rocky, but after a researching a lot here and looking at specs of machines i ended up with a Bezzera BZ99 & Macap M4 stepless , the total of both gave me some change from $3k to get some great coffee and some accesories.
              There are a great deal of machines available as you know, good luck in your journey & choice.
              I have just started discovering howlittle i know about coffe - but looking very forward to what lays ahead.
                HX machine is what you need
                Originally posted by 06292022350A26292620222A222933470 link=1241427441/5#5 date=1241435807
                Use the sponsor link and contact them..A few specials going at the moment and some great buys..
                Yes I second that
                Also this little beauty from the Equip For Sale section
                Virtually unused ISOMAC MONDIALE $2550
                http://coffeesnobs.com.au/YaBB.pl?num=1240067976#top
                  Hi.
                  Exciting time - picking a new machine.
                  I have an Elektra, as well as an ECM Giotto. I like em both, but youll find the ECM is more user friendly, and probably cheaper.
                  Why? Bigger drip tray, less cooling flushes needed (particularly if you get the thermostability mod from Chris at Talk Coffee), can dispense hot water, the whole lump doesnt heat up and burn the unwary (just the group head, which can really decorate your belly if you arent alert when filling the reservoir), and ability to put taller cups under the group head.
                  On the other hand, that Elektra is a cool looking beast, and can make a good espresso, also steams milk servicably. The other limitations can be accomodated. And jeez, it looks so much better than a crappy Sunbeam.
                  If you arent in a hurry, keep a look out for a good 2nd hand machine - most are pretty good. I dont have experience of the Sunbeam you mention, but would give them a big miss, especially since you can afford something a whole stack better.
                  Where abouts in "country vic" are you?
                  shaun
                    http://coffeesnobs.com.au/YaBB.pl?num=1239776171
                    By it before I do!
                      oops, that should have been "Buy it before I do!"
                      This is easily the best value machine currently available to suit the OPs budget and requirements (and I still cant believe it hasnt sold yet)
                        Had a number of people interested at the start, but looks like the wives have been putting their feet down pretty heavily.    :
                        Havent even had one person come by to even look at the machine as yet, and have been tempted to put it up for sale elsewhere.  The only thing is that Ive grown fond of her and Id rather she be well taken care of by another CoffeeSnob, so Im just leaving her at my parents place and making coffees for them every time I go over.
                        Anyway, back to the OPs question - for that price, any of the machines should have commercial parts and build to last, and even if there are problems should be easily repaired.  I would recommend a HX or double-boiler machine if you plan on making milk-based drinks.
                        Oh... and make sure you get a decent grinder - at your budget, there are heaps of possibilities from the Rocky to the Macap/Mazzer.
                          Hello,
                          I am currently looking at an offer from a website online which would include a grinder, a scace temp calibrated Domobar Levetta and accessories - this is just over $2K.
                          What HX machines are equivalent or better than the Levetta
                          Also what Doser based grinder would be good for this too? I am leaning towards the Rancilio Rocky.
                            Originally posted by 5F474B5F425E592D0 link=1241427441/12#12 date=1242738494
                            Hello,
                            Do some more reading and searching on CS and then contact ALL the sponsors.... Via their single e-mail address ( At the bottom of the list) ..
                            Service support and ongoing assistance is worth so much more that a few $$ cutting corners.
                              Originally posted by 6E767A6E736F681C0 link=1241427441/12#12 date=1242738494
                              Hello,
                              Is the domobar you at looking at HX?
                              searching yields mostly the piccolo been called the levetta, which is a single boiler design - which is what Im expecting given bit over $2k including a grinder.
                              If you drink espresso only, then its hard to see why you would want a HX for mine. HX is about doing the whole milk based drink easily and efficiently imo
