Help with a La Cimballi Junior
  • DiBort
    Re: Help with a La Cimballi Junior
    Sparksy;
    Unfortunately, I do not have much experience with this machines, but Coffex Coffee use to be the importer to Australia. I suggest you to give them a call they should be able to help.
    regards
    Renzo
  • sparksy
    started a topic Help with a La Cimballi Junior
    Hi
    As you can see Im new and have little experience with coffee machines, spend most of my time looking after 1000kg/hour chip fryers,
    I recently picked up literally on the side of the road during throw out your dead, a cimballi junior in not too bad condition. Complete bar the part that the coffee actually goes into. I intend to rebuild it as a winter project but a problem I have is all the wiring is there but not connected, so I need a wiring diagram to work from. Im hoping that you guys will help out.
    I cant find a serial number but there is a green sticker on the RHS with F27 hand written next to "code". The unit has no electronics in it bar a Gicar level controller and has two large control knobs with a push button between them.
    Wayne
