Filter leaking/overflowing
  • Filter leaking/overflowing
    I had a search but couldnt find anything that matched.
    Ive noticed that at times, during extraction, I get a runoff that starts dripping off the handle during extraction. Its as if the filter basket is leaking or overflowing somehow.
    It doesnt happen always. Its only started happening in the last few weeks. Dose and tamper are unchanged. I realise its not 100% identical every time, but its as consistent as I can get it.
    Any ideas?
    Machine is a Bezerra Domus Galatea.
    Re: Filter leaking/overflowing
    Might be the rubber seal on the group head??
    Have a look under the group with a torch.
      Use a group head bush to brush around in the group ring area, then use the blind filter and do "the jiggle" to wash those grinds away until the overflow runs clean.
      If you still get a leak over the top after you have done that there are 2 scanarios:
      1) you could be overfilling the filter with grinds, or
      2) the group seal could be in need of replacement.
      Hope this helps.
      Regardz,
      Attilio
      very first CS site sponsor.
        Originally posted by 07332432291E022E27272424410 link=1244123173/2#2 date=1244159345
        I agree with Atilio
        Also could be that you have damage the basket, if you knock off the coffee in the sink.
        Question is dripping water or coffee?
        How old is the machine?
        Renzo
          Thanks for the replies.
          Just walked in the door, so I havent yet had a chance to look at the o-ring. But to answer some of the questions here:
          1. I have the brush, and clean up around the group head regularly.
          2. The machine is about a year old.
          3. Its dripping a weak-ish coffee. Or just stained water.
            Thanks for the replies again. Looks like it may be the seal. I thoroughly cleaned the group head yesterday. It wasnt very dirty anyway. The seal looked ok however.
            First coffee this morning, and it leaked again. Oh well.
            How long is the life on the sealing rings anyway?
              I say on average 6 - 12 months depending how many coffees you make and how many times the machine has been switched on/off in that time.
                Replace this seal is pretty easy, enclose some information that i found.
                http://espressoparts2.zoovy.com/category/espressotutorials.e61groupmaintenance/
                your machine is 8mm
                Regards
                Renzo
                Di bartoli Home Barista Centre
                  Cheers.
