Hi
I would like to find out how I can access the ECM Technika III OPV. Can it be accessed from the top or do I have to remove the side cover to get to it?
If it is the latter, how do you remove the side cover? :-?
Using a blind filter with the pump running, the pump pressure gauge shows 14bar and I want to set it to 10bar. I assume tweaking the OPV counter clockwise will reduce the OPV pressure.
Thanks.
Thanks.
