Procon Series 3 in espresso machine
  • odannyboy
    Re: Procon Series 3 in espresso machine
    Thanks Maheel. Ordered from US so no returns poss... Fortunately only $70 delivered (Yay the exchange rate)
    Maybe Ill flog it off and order another, unless there is someone here who can do a rebuild on the original.
    Or try it and see...
  • maheel
    contact your supplier before installing they may swap you for the right one +- a few $$? if it is a site sponsor it might help
    but if your running on mains pressure at 3 bar you should get the 130 psi you need for 9 bar if they will no return it
    good luck, dont forget the pictures
  • odannyboy
    started a topic Procon Series 3 in espresso machine
    My procon pump was leaking, so I quickly ordered the wrong one... Series 3 stainless steel 125psi with 3/8 inlets.
    I havent installed it yet, but I assume with half the normal pump pressure I will only get half the pressure out of the group head?
    Running Boema 2 group.
    Dan
