question - Giotto PP or giotto premium?
  • #46
    Re: question - Giotto PP or giotto premium?
    Originally posted by 47464C5F41445E2D0 link=1261350236/44#44 date=1264731188
    If its an ECM Giotto than I assume its past its warranty anyway.
    touche
    Well with that in mind.....
    This is how i did it......TURN OFF POWER, UNPLUG FROM WALL
    1. remove reservoir cover, water reservoir and unscrew top plate and the plate under that which covers the boiler.
    2. Now on mine (GPP) i have the pressurestat on the right hand side in a black plastic box, on top of that is a yellow cap, remove it carefully(dont drop it)
    3. stick a large flat blade screwdriver into the whole and locate the screw adjustment, + and - is marked on the top, + to raise pressure, - to lower pressure.
    I did it 1/4 of a turn at a time testing all the way, i had the POWER OFF the whole time i had the top cover off.
    I tested by replacing top cover, turning back on running some water through head, letting some steam out and see where the boiler turns off and on.
    I ended up making 1 complete turn to the - bringing the pressure down to 1.2
    Test your shots too, thats what this is all about, note flush times etc
    I am in no way an expert on this, if you have any doubts whatsoever im sure a sponsor will help out over the phone.
    cheers
    warren
    • #47
      Great advice Warren - thanks for all the detail.
      Ill definitely give this a try soon.
