Re: question - Giotto PP or giotto premium?
Great advice Warren - thanks for all the detail.
Ill definitely give this a try soon.
toucheOriginally posted by 47464C5F41445E2D0 link=1261350236/44#44 date=1264731188If its an ECM Giotto than I assume its past its warranty anyway.
Well with that in mind.....
This is how i did it......TURN OFF POWER, UNPLUG FROM WALL
1. remove reservoir cover, water reservoir and unscrew top plate and the plate under that which covers the boiler.
2. Now on mine (GPP) i have the pressurestat on the right hand side in a black plastic box, on top of that is a yellow cap, remove it carefully(dont drop it)
3. stick a large flat blade screwdriver into the whole and locate the screw adjustment, + and - is marked on the top, + to raise pressure, - to lower pressure.
I did it 1/4 of a turn at a time testing all the way, i had the POWER OFF the whole time i had the top cover off.
I tested by replacing top cover, turning back on running some water through head, letting some steam out and see where the boiler turns off and on.
I ended up making 1 complete turn to the - bringing the pressure down to 1.2
Test your shots too, thats what this is all about, note flush times etc
I am in no way an expert on this, if you have any doubts whatsoever im sure a sponsor will help out over the phone.
cheers
warren
Ill let a sponsor answer that one, i believe it can void ya warranty? i did it cause i didnt wanna send it to gold coast to get fixed up
Thanks, Im going to insulate my boiler soon. This should help.
How did you adjust/reduce your pressure range? Sounds good.
i suppose it also depends on the climate you live in/insulated boiler or not and pressurestat settings for on and off times, but my on off time did slightly improve when i stacked 18 cups on the cup warmer, better heat retention i suppose.
My Pressure gets to about 1.2 off and 1.05 on after an adjustment, when i first got the GPP it was 1.3 and 1.1, i found my shots a little bitter, now they are sweet
cheers
warren
Hi again all,
My boiler switchs on for about 10 seconds every 70 seconds.
ie - Pressure drops to 1.1 bar, boiler on for 10 seconds, Pressure gets to about 1.22 bar, pressure drops to 1.1 bar in 60 seconds then repeats.
Does this sound the same as others?
I descaled when last week so this may have also helped with my steaming pressure.
that could take a few trees! ;DOriginally posted by 6253475E4B060206320 link=1261350236/34#34 date=1264406094Now I need to off-set the roasting .. ahhh....
Mine does that at the end of a 1 lt jug, so as long as it gets to the right temp without stalling, shouldnt be a problem, having said that, i just did another descale and my steam power has increased, so im a happy chappy!Originally posted by 515354576D5E5D445740320 link=1261350236/37#37 date=1264552033It holds pressure ok till the end of steaming but the meter showes just above 0.5 when I steam.
Should I be worried?
I think I have early Rocket one after they took over from ECM. It has batch number start with 2007 but was sold in 2008 - I was told. It has Rocket Expressor Giotto batch. I think they are sme machine anyway.
My 2007 ECM Giotto holds pressure when steaming without any problems.
I am considering a talk Coffee thermostability mod in the near future but still doing some research.
In the end I bought GP 2007 model but sold in 2008. I found the pressure went down to about 0.5 but it recovered quite quickly. The coffee I found it starts a little slow initially at around 8-10 sec but the taste in the end was great. I started enjoying black coffee. Ill probably work down to expresso slowly.
I am still thinking whether I need to modify GP.
Ill plant one tree and run my machine for only 30 minutes before each morning fix, then switch it off - should make my coffee brewing be carbon negative. Now I need to off-set the roasting .. ahhh....
I dont think we should be moving to carbon neutral but carbon negative, because we have years of carbon emissions that need to be counter acted.
Ive got two coffee trees; does that count?Originally posted by 5E6F7B62773A3E3A0E0 link=1261350236/31#31 date=1264393388Ill plant an extra tree to get my coffee carbon neutral ;D
