AAAAAGGGGGHHHHH My Bezera (BZ70S) wont fire up. Life is over.
  • AAAAAGGGGGHHHHH My Bezera (BZ70S) wont fire up. Life is over.
    HELP HELP HELP
    Just went to turn on the coffee machine, draws water but wont heat up or show any pressure on the gauge. :-/
    Used it yesterday no problems at all, backflushed it all as normal.
    Is life over ?
    Any suggestions from some of you gurus out there ?
    Does this mean I can justify ordering my Speedster ? ;D
    Thanks all
    Chester
    Re: AAAAAGGGGGHHHHH My Bezera (BZ70S) wont fire up. Life is over.
    I dont know your machine, but in general if you have a multimeter id check the element and the pressurestat first.
      Just order the Speedster. Dont check anything--you might find a cheap cure. ;D
        Turn on machine
        Open the steam nozzle (and leave open) as it may be an air lock
        Leave on until you hear a hissing sound [up to 30 seconds] then close the steam off
        If that does not fix it it will be one of 2 things
        1] Pressure switch
        2] Heating element
          Originally posted by 003522201028352A262B23470 link=1276079923/2#2 date=1276085567
          KISS... I like it :
          And then if ya desperate
          Try the following
          Originally posted by 0C2821212222180C28342A28470 link=1276079923/3#3 date=1276138086
          Turn on machine
          1] Pressure switch
          2] Heating element
            Thanks for the advice, alas she still doesnt offer me coffee.
            Luckily I found my receipt and still have a month of waranty left ;D
            so off to the shop she goes.
            Sadly, Amanda thinks this is a better idea than ordering the speedster.
            HHHMMMM How do you blow up a coffee machine ?
              Its not impossible that you have tripped the thermal cutout on the boiler :-?
              More likely than not though, an element. Its possible/probable that you may find it not covered by warranty though as most manufacturer warranties exclude elements.
              Good luck
                Originally posted by 6D322A3C373C3039393A3A323E315F0 link=1276079923/6#6 date=1276172144
                All true...
                AND
                Originally posted by 3C302C32363C003C302A2F333A6D6D5F0 link=1276079923/5#5 date=1276171161
                Much easer than many might thing and plenty of different ways to do it..
                First thing to remember... 98% of teh faults are all USER induced.
                  Bezzera coffee machine have the pretty look but their coffee shot is to quick. under 20 seconds. My advice is "Change it as soon as you can"
                    Suggest USER rather than Machine.. Try fresh beans and the right Grind and tamp..
                      Had a similiar problem recently with my Isomac Tea - turned out to be the electronic control box and I had to replace it.
                        Please elaborate. :-?
                          Re: AAAAAGGGGGHHHHH My Bezzera (BZ70S) wont fire up. Life is over.
                          Sorry ciatuo but I disagree completely...
                          If your experience with Bezzera is too fast in the shot department, you have one or more of the following issues:
                          • underdose
                          • incorrect grind
                          • poor technique- incorrect grind and/or tamp. Adjust the nut on the group handle...
                          • stale coffee
                          • inadequate grinder
                          A bad tradie always blames his tools :
                            This and a few others sounds more like a quick post or 3 before a post in teh FS section..
                              Originally posted by 745B52504778545B54525058505B41350 link=1276079923/13#13 date=1276493561
                              Looks like ya picked it in one AM.
