Re: Maintenance of water softener/filter on end of water intake pipe
Okay, Ive bought a new in tank resin filter, thanks to Coffee-A-Roma. At $7 Ill be buying one every 3-6 months.
However Ive been doing a bit of research on the Brita, and it seems it already has some resin ion-exchange filtering. This is the contents of a standard Maxtra cartridge:
* Pre-Filtration: the water flows through a fine mesh filter - simply fill from the tap.
* Ion Exchange Filtration - the ion exchange resin reduces the heavy metals, including lead and copper, as well as the carbonate hardness that causes limescale build-up in kettles and affects the taste and aroma of tea or coffee.
* Activated Carbon Filtration - the granulated activated carbon significantly reduces substances that affect the taste and odour of your tap water, such as chlorine, certain pesticides and organic impurities.
* Final Filtration - fine mesh particle filter.
* MAXTRA Flow Control - ensures a consistent flow rate through the cartridge and optimises the contact times between water and filtration media for superior performance.
Im wondering what further technology is utilised by the special coffee filtering systems?
