No Pressure - Diadema Junior Plus
  • No Pressure - Diadema Junior Plus
    Hi,
    I woke this morning and my My beloved Diadema Jnr has suddenly no pressure... I heats and the pump is working but no pressure.
    Im guessing its the pressure stat... but Im hoping it something simple like a fuse.
    Any ideas?
    Merr1
    Re: No Pressure - Diadema Junior Plus
    Originally posted by 0F07101053620 link=1309044496/0#0 date=1309044496
    Hi,
    Any ideas?
    Merr1
    Where Merr1?
    At the group? From one of the wands?
    More info will help
      Theres no pressure at all anywhere. Gauge doesnt even move.
        But it heats???
          Yep. Pump is ok... hot water out of head etc...
          So, no steam... and normally you can hear the machine build up pressure. But it sounds dead today. Just heats and thats all.
            Most likely the steam wand is blocked and/or the anti-vac valve needs replacement. Remove or unblock the tip, open the wand and then fire up the machine and see what happens.
              Ok... Sorry, Its not actually heating up at all.
              Sorry for the confusion, my wife told me informed of the machine not working this morning. It must have ceased heating after initially functioning correctly so water in group head was still hot.
                I know this may seem a silly thought?
                But is your water tank full?
                This can happen if the low water level switch activates
                Yes it can happen even after it heats the water
                All it takes is the level to fall below cut off
                Once that happens you get nothing
                  Hello there,
                  before doing anything else, lift the lid on the water tank and check water level as mentioned above. Lift the tank up and down a little...push down to make sure the under tank microswitch is properly engaged, and see if all is ok / goes back to normal.
                  Attilio
                    Hi, yep... checked the tank and ensured safety wasnt on by accident.
                    I just checked my original docs... and of course its about 2 week out of the 2 year warranty period.... great!
