Re: No Pressure - Diadema Junior Plus
Hi, yep... checked the tank and ensured safety wasnt on by accident.
I just checked my original docs... and of course its about 2 week out of the 2 year warranty period.... great!
Hello there,
before doing anything else, lift the lid on the water tank and check water level as mentioned above. Lift the tank up and down a little...push down to make sure the under tank microswitch is properly engaged, and see if all is ok / goes back to normal.
Attilio
I know this may seem a silly thought?
But is your water tank full?
This can happen if the low water level switch activates
Yes it can happen even after it heats the water
All it takes is the level to fall below cut off
Once that happens you get nothing
Ok... Sorry, Its not actually heating up at all.
Sorry for the confusion, my wife told me informed of the machine not working this morning. It must have ceased heating after initially functioning correctly so water in group head was still hot.
Most likely the steam wand is blocked and/or the anti-vac valve needs replacement. Remove or unblock the tip, open the wand and then fire up the machine and see what happens.Originally posted by 40485F5F1C2D0 link=1309044496/4#4 date=1309047738Yep. Pump is ok... hot water out of head etc...
So, no steam... and normally you can hear the machine build up pressure. But it sounds dead today. Just heats and thats all.
Theres no pressure at all anywhere. Gauge doesnt even move.
Where Merr1?Originally posted by 0F07101053620 link=1309044496/0#0 date=1309044496Hi,
I woke this morning and my My beloved Diadema Jnr has suddenly no pressure... I heats and the pump is working but no pressure.
Im guessing its the pressure stat... but Im hoping it something simple like a fuse.
Any ideas?
Merr1
At the group? From one of the wands?
More info will help
Hi,
Any ideas?
Merr1Tags: None
