Futurmat Ariete 1gr - how to handle tripped Level Safety device
  • Futurmat Ariete 1gr - how to handle tripped Level Safety device
    Dear all,
    The LED´S of all touch pads are blinking. And the only touch pad that functions is the one for “Continuous brew “. The automatic refilling of the boilertank does not function but heat is ok.
    How do I handle this tripped Level Safety deviice - Do I need to change a component?
    Niels
    Re: Futurmat Ariete 1gr - how to handle tripped Level Safety device
    Niels,
    It sounds like the control box has gone on your machine. The quickest solution is to simply replace it. The cheaper one (works often but not always), is to check the capacitors etc on the board. Often you can get it all working again by simply replacing a few components on the board.
    I do this myself quite often (for myself and others), and works about 80% of the time.
