Slight leak from Isomac pump found.
  • Slight leak from Isomac pump found.
    Anyone had a leak coming from where the threaded union connects to the pump?
    I noticed it today when adjusting my OPV. Its only a slight leak so I think i should be able to seal it easy enough.
    Re: Slight leak from Isomac pump found.
    Careful you dont crack anything which is relatively easily done in these situations
    Careful you dont void your warranty (if the machine is still in...)
    Careful you dont electro-kill yourself
      Im not going to remove it, just seal it. Its not much of a drip at all.
      Good warnings though!
