Giotto Brew Temp
  • Giotto Brew Temp
    I just got a new Rocket Giotto & thought Id post the results of my brew temps.
    Using a Scace 1 device the results were a little disappointing. Right out of the box it was stable but low. Directly after a 2 sec purge the initial few secs were at 86, then slowly ramping up to 90 over the next 5-10 secs than sat ~90 for the remainder of the 25 sec test.
    I repeated this several times with the results being much the same.
    Also the pressure at the head was high, 10.5bar
    Phil
    Re: Giotto Brew Temp
    Phil
    Interesting Phil,
    Thats about wed expect of an unmodified machine- straight out of the box- prior to bench testing and calibration.
    Sounds to me like your dealer might have just switched the machine on to check that it worked :-?
