For those of you that love your Vibiemme Domobar as I do and enjoy wiping down the stainless and emptying the drip tray, you will have noticed that the object of your affection is actually laced with razor blades. That is, there are sharp edges everywhere. Some of the worst have razor sharp flashes left over from the stamping process. You can feel them with your finger nail. I’ve run a small fine grinding stone lightly over all the edges. This has done the trick. It will still cut you if you want it to but not as easily. If you are careful with the stone, there is no visual impact at all.
One would have thought VBM would have someone run a tool over the edges prior to assembly. This may add a few dollars to the cost but the CS would quickly recoup it through savings in band-aid costs.
