Squeaky and stiff Giotto lever
  • #16
    Re: Squeaky and stiff Giotto lever
    Once a month is good. Run a couple of shoots after see it make any different. Other wise try the lubricants.
    Good luck
    Renzo
    • #17
      Guys, I picked up some grease from Jaycar today & just did my VBM. Smooth as silk now. My biggest regret is that I didnt do it years ago. I couldve avoided the wear on the cam. I might make this a regular ritual every few months when I change my group gasket.
      A big thanks to flynn_aus for the "how to guide" & KK for his advice on where to get the grease.
      Evan.
      • #18
        Evan.
        Although I knew about the grease as I am frequently popping in @ Jaycar
        Mal first raised it on a post a while ago
        So I cant take credit on that but I will take the credit on passing on that information
        Glad to hear all is working well again Evan
        • #19
          Bought some grease yesterday and plan to do the same job over the weekend.
          Mal
          • #20
            I bought some grease today from my local hardware store - the INOX Grease which is the same as the Jaycar one. Will try it in a few days when I receive my other parts from Di Bartoli (thanks!).
            If anyone does this task this weekend on a Giotto Premium, any photos you have of the process would be extremely useful. As 2muchcoffeeman pointed out, it is important to remember how things go back together.
            • #21
              Hi cremachine
              I will be doing this today or tomorrow so will document and advise. Hopefully all will go well and i wont be on Talk Coffees door step requiring Chris to complete the job ;D
              Mal
              • #22
                Cremachine
                Its really easy, have written and taken pics so will post to my website shortly and provide a link.
                Very daunting contemplating pulling apart the baby but it was a real breeze
                Mal
                • #23
                  Just a caution when greasing your machine:
                  **Ensure all cups and glasses are out of the way of falling spanners!**
                  Oops--down one Bodum glass. :-[
                  ps--the Inox grease from Jaycar works a treat.
                  • #24
                    Hi Greg
                    Totally agree with you on the Inox grease, the action is now as smooth as silk.
                    Mal
                    • #25
                      Originally posted by 44494A44260 link=1236205891/21#21 date=1236404805
                      Cremachine
                      Mal
                      Hi Mal,
                      Thank you in advance. It will provide an excellent record for all us who are likely capable but also feeling a little daunted taking this on.
                      Regards.
                      • #26
                        Update:
                        Since cleaning & greasing, Ive noticed a small water leak from the shaft during the pour. Just wondering if anybody can advise on which seal/s I should target.
                        TIA,
                        Evan.
                        • #27
                          Originally posted by 0516600 link=1236205891/25#25 date=1236559119
                          Update:
                          TIA,
                          Evan.
                          Hi Evan,
                          If you have a look at http://coffeesnobs.com.au/attachments/Giotto_parts_p_1-3.pdf, the seals are part #219900426
                          You may find that simply reseating them will do the trick.
                          Good luck
                          2mcm
                          • #28
                            Thanks mate. It was the only rubber seal I pulled out so I guessed as much. In my machine though, it looked like one fat seal, not two as shown in the diagram. Ill rip it out later & have a closer look. I might add some grease on the side that mates with the brass sleeve. If I need a new one, do you carry them for the VBM?
                            Evan.
                            • #29
                              Cremachine
                              Here is the documentation i have writtne on the process.
                              http://www.bolb.com.au/index.php?opt...hines&Itemid=2
                              Everything went fine and the lever action is smooth.
                              Mal
                              • #30
                                Mal, the cam on the end of the shaft will most likely need greasing. I even went as far as polishing mine up with 800 wet & dry to take the steps out. The VBM is a little different but looking at the Giotto diagram, I guess youll just need to remove the big chrome nut. If the lever is in the middle position, the shaft should just fall out. Maybe Chris or others can confirm this.
                                I can now confirm that my VBM uses a single 9mm rubber seal unlike the dual seals pictured in the Giotto diagram. Ive greased mine well & reseated the brass sleeve against it. Its working fine now but will need replacing soon as its starting to crack & perish. Any advice on where I can get one will be greatly appreciated.
                                Evan.
