Giotto Premium Plus Auction- discussion thread....
  • Giotto Premium Plus Auction- discussion thread....
    This thread is for discussion of the Silent Giotto auction completed on 18/3
    Attached graphic of the defective group showing a dull patch to the right side of the group behind the sticker....
    Re: Giotto Premium Plus Auction- discussion thread....
    Chris,
    please excuse my ignorance, but regarding rechroming, am I right in assuming that these groupheads are all brass? Is the dismantling of the grouphead a complicated process?
    The rechroming I can get my head around, but I am still only getting into the swing of HX machines!
    Would a picture a little further away be possible? It is hard to get any contrast from your current picture.
    Many thanks.
      takes a little work to remove the group head and personally i wouldnt bother.
      If you really want to know how to do it i can post up some pics
        Originally posted by 262D24277F707C480 link=1236809380/1#1 date=1236820873
        Chris,
        Many thanks.
        Hi Nelo,
        You will see a slight dulling to the rhs rear of the sticker. Its very difficult to get a photo of. This machine is perfect other than this small issue.
        It is not that difficult to remove and replace the group, but I personally wouldnt bother.
          Originally posted by 04313C3B0F133F36363535500 link=1236809380/0#0 date=1236809380
          This thread is for discussion of the Giotto auction posted: http://coffeesnobs.com.au/YaBB.pl?num=1163933911/5#5
          Bidding is currently at $1900 on this machine (RRP $3000)
            Bid is now $1950.
            Bidding ends on Wednesday at 5PM AEST and can I request that the increment be $50.
              testing
                JohnA.......itd be nice if you could post some pics of removing the group.
                thanx
                  its fairly simple.
                  Basically you take the top off the machine. 2 bolts holding it in place and there are 2 brass fittings to remove also.
                  this next photo shows you the 4 bolts holding the group in
                  you should be able to get to all this with just the top off.
                  This was my machine which i had stripped and cleaned
                  and here it is removed. There is also a gasket
                  here is the view with just the top removed.
                  As you can see, you can get to all parts that need removing
                  at the current price, this thing is a steal
                    Bid is at $2150 and this machine will sell at 5pm.
                    We ran a bench test yesterday and the flaw is very minor- you have to look for it. Great opportunity to save $$$ on a new machine
                    Also, 20% profits will be donated to FairCrack....
                    Grab it before its gone
                      Bid at $2200
                        Bid at $2250
                          $2350 and 3 minutes to go...
                          Going, going......
                            SOLD to CS member Graham for $2350.
                              And the winner is?
