Ive done all the listed mods and also used some windscreen washer hose off a Holden Sedan for the "split hose mod" That seemed to work better than the teflon tape. No east/west movement, and to adjust it it just requires firm pressure to turn the hopper.
I did both, some silicone fuel tube from R/C models, and teflon tap on the bur carrier. I used some of the fuel tubing to permanently depress the lever so I have stepless adjustment, which is what I read the mod was for. I have zero wiggle in mine, and it doesnt budge in the slightlest when the grinder starts, it sounds a lot different and produces a much different grind. I think only the teflon tape was requred, I have a pretty big gap between my hopper and the metal casing, the fuel tube barely touches, and is instertable/removabe with the hopper installed. The hopper was a pain to reinstall though, with a few layers of thread tape the thread is quite tight.
I also have a Domobar Super, and althought I havent tried another grinder, I certainly have no gripes with the quality of the pair now. I think with a Rocky youre suitably equipped to get a new machine without having to fork out for a new grinder. That said, a friend mine (sink cut? havent seen him around for a while...) had the same thing as me, I think, and upgraded to a Mazzer SJ and said the difference was significant.
While Im here... Ive heard about the click clack thing... how does it work? I thought it was just a different lid for it? how does it allow you to "pump a amazing amount of excess ground coffee out of the spout."?
Hi Sammus, I will stick with the Rocky at least in the mid term and am planning to visit one of our sponsors in the next month or so to have a play with one of the new Juniors. With the CC lid, you use it as a type of plunger as it seals in the top of the hopper and as you push it down it creates a "gush" of air which in turn expels some of the ground coffee caught in the outlet chute. The canister cost around $12 from K-Mart and I now have the original hoppers lid on it with tea bags stored in it. Worth while doing.
