Ponte Vecchio Lusso Club Spring Lever espresso machine
  • I'm looking to get some replacement seals for my lusso which I got from sorrentina coffee a couple of years ago.
    I have looked on the la macchina del coffee website for parts and have got myself a bit confused about which seals I should be getting. Should I get the 5mm (KIT-PV5) or the 6mm seals (KIT-PV6).
    Thanks!
    • For those who are replacing seals on their Ponte, I refuse to pay $40 euro per set, so I took the old seals to my local hydraulic shop, and they were able to supply me some V-seals.
      These are standard hydraulic V-seals, nothing fancy. 1" x 1.5" x 0.25" (Or 25.4mm x 38.1mm x 6.3mm). I managed to get a set of 6 x poly v-seals, rated for 6000psi heavy duty hydraulic pistons for $14.55 each, cheaper if you go standard low pressure rubber seals. Give them a good clean and wipedown with alcohol before installation.
      They will probably outlast the machine.
      • do you think the same seals would work for my pv export? i think original gaskets are 27*39*7
