Diadema Junior Extra - Low Shower screen?
  • Diadema Junior Extra - Low Shower screen?
    Do the DJEs have a very low screen? Well after playing with a 5 cent piece Ive discovered they do.
    Well I thought I was going pretty well with my technique on my new DJE...but after recently doing the 5 cent test, Ive discovered Ive been over dosing the double basket. After packing the basket with a couple of taps on the way, and leveling off I tamp quite hard and still the 5 cent piece gets stuck on my shower screen.
    Anyway so same procedure except this time, I ground finer. After a decent tamp...the neck of my tamper is now flush with the top of the basket. I put the 5 cent on top...and still gets stuck
    What do you think I should do...not level off and just tamp on top of the mound (Ive seen this done by a few Batistas competing in comps)...or grind even finer? Im already seeing a little wetness on top of my puck.
    Any ideas and advice would be great.
    Thanks,
    IB
    Re: Diadema Junior Extra - Low Shower screen?
    Hello Italian Bean.
    Sorry but cant go past this one.
    Suggest you talk to your supplier re your operational technique because the DJE uses the same group head & shower as all other E61 machines use, and as far as I know none of them have "low shower screens" or, if the DJE has it... then they all do.....!
    Regardz,
    Attilio
    very first CS site sposnor.
      Agree with Attilio IB...
      My Double Shot dose runs to 20g+ and after a 10Kg tamp, it does not contact the Shower Screen before the shot is pulled. I think you may be trying to dose way too much in the basket mate....
      Try adjusting your dose downwards until such time as you achieve clearance from the Shower Screen, taking note of the volume of ground coffee used at this point so the Dose can be consistently repeated. After this, just adjust the Grind Setting Coarser/Finer to achieve an ideal pour volume in the requisite time frame...
        Hi IB,
        You are most welcome to pop in with your machine and grinder and well gladly run you through how to get the best from it. Alternately, we can use our demo model Diadema Regal and your own grinder (and coffee if you like), so that you have something you know is right when you get home- environmental variables notwithstanding!
        I agree with Mal and Attilio, that its consistent with other machines.
        For mine, the 5c test is relatively crude. Better to learn a few different ways of dosing to allow you to consistently put a great result into the cup.
        If youd like to give me a buzz, we can arrange a time....
          Originally posted by 6F5A57506478545D5D5E5E3B0 link=1271933172/3#3 date=1271938369
          Yep, I agree Chris....
          I spose its a good starting point for a newbie 1,000Km from the nearest service centre but if youre only a stones throw away from one of our Site Sponsors, then its a no brainer really....
            Thanks guys for your feedback.
            The reason I was thinking it was the shower screen is because Ive heard from a number of people that depending on your machine the height of the screen will be different. I didnt know that all e-61 heads have the same shower screen height relative to the top of the group handle when locking it in.
            If I do a clearance test without the 5c piece by locking in the group handle and then unlocking without pulling the shot. Should I be seeing a depression on my tamped bed of coffee. What I see is a perfect ring about 2-3mm thick that is on the outer edge of my basket. I am assuming this is caused by the gap between my screen and the seal. Which indicates overdose, right?
            So is it safe to say if I do the same test and gradually reduce my dose until I dont see this ring around the outside of my tamped bed of coffee I am on the money with regards to clearance? Should there be a slight depression in the middle of the basket (i.e the screen just brushing the surface)?
            Chris - thanks for the offerr..I may just take you up on it.
            IB
              Originally posted by 64515C5B6F735F56565555300 link=1271933172/3#3 date=1271938369
              To an experienced person it may be crude... But to those starting out..
              Originally posted by 7944515C59515E6F7255515E300 link=1271933172/0#0 date=1271933172
              What do you mean gets stuck..
              In essence what ya trying to do is to work out a dosing / tamp that allows enough space for the coffee to expand, once wet; so that it is NOT overly compressed up and into the shower screen.
              If ya use a 5cent piece and dose / tamp and then lock in and then remove and teh coin is compressed into teh puck.. Ya overdosing.. If ya thing about it.. Its like a second tamp and then when the water hits; it like adding a third tamp...
                Originally posted by 5F70797B6C537F707F797B737B706A1E0 link=1271933172/6#6 date=1271976698
                When I say gets stuck I mean that the 5c piece along with some amount of coffee is stuck to my shower screen after unlocking the group handle and removing (and this happend after I thought my tamper was sinking way too deep in my basket).
                So should the 5c piece touch the shower screen at all? If it should just lightly touch then this could be skewing my test by getting stuck and lifting off some coffee from my tampled bed in the process....giving me the false reading that Ive dosed to much coffee.
                IB
                  Originally posted by 013C2924212926170A2D2926480 link=1271933172/7#7 date=1271985610
                  This is a DRY test, done with no water at all.
                  Sounds like you might be pulling a shot at the same time.
                  Dose, distribute, tamp, place 5c piece on top, lock Gh into group as per normal, unlock and check to see if or how far the 5c piece has been impressed into the puck.
                  NO WATER USED
                    NO WATER USED
                    Hi there shawty...Im definetly not pulling the shot with the 5c piece in my filter basket ;D
                    Im just sharing my findings after playing around with this 5c method for the benefit of other CSrs and also for fine tuning my own technique and procedures.
                    IB
                      Originally posted by 477A6F62676F60514C6B6F600E0 link=1271933172/9#9 date=1271993369
                      Not a false reading at all... If the coin is forced onto the shower screen and or pressed into the coffee puck... Too much Coffee.
                      Dose / Tamp / coin / Lock in and then remove should leave a slight depression...
                      Now the issue is, if ya have a BOLT like in some machines that hold the shower screen in... Move the coin or try 3 or 4 coins around the edge.. Ya will soon see how level you are with tamping and or the way you lock in..
                      You will find that ya not a good as ya think
                        Just one question......why is your coin sticking to your shower screen? last time i checked my shower screen is not magnetic? Is it gummed up with oil? :-?
                          Yeah thats a good question. I didnt think it could happen. But after playing around with this 5c test last night...it happend twice. The coin and thin layer of coffee from my tamped coffee bed gets stuck on the shower screen....only for a few seconds then falls down on to my tray.
                          As AM said...Too Much Coffee
                            Originally posted by 526F7A77727A7544597E7A751B0 link=1271933172/12#12 date=1272000564
                            To do this sort of experiment, the shower-head, the Group and the Group Handle all need to be perfectly dry. Its probably water/moisture that is causing this to happen.
                            The best time to try this out, is when the aforementioned components have had a chance to become perfectly dry, i.e. probably overnight after clean-up following the last coffee session for the day and before Switch-On the following day. The Group and associated components should be nice and dry by this time....
                              Hi Bean,
                              Youre not seeing the coffee for the beans.
                              I dont think youve said what the coffees like. As Chris has said it is whats in the cup that matters.
                              Put the coin back in your pocket and if the shot tastes good dont worry about it - just drink the stuff.
