VBM Piccolo group head gasket size?
  • krnjoejoe
    Re: VBM Piccolo group head gasket size?
    Thanks for the replies will probably go with the 8mm + spacer.
  • DiBort
    Joe;
    Try by using the 8mm and get an spacer in case.
    http://www.dibartoli.com.au/product_details.asp?pid=284
    http://www.dibartoli.com.au/product_details.asp?pid=197
    Regards
    Renzo
    Di Bartoli Home Barista (Spare Parts Dept)
  • Randy_G.
    If the Piccolo has the same screen with the metal rim on the face of the screen spot welded as the DS comes with in the States (and I would assume that it does), go ahead and change it. There is a quality replacement available that can be identified by a sort of indentation that goes all the way around the circumference of he body, about 3 or 4 mm above the face. It is much stronger and much easier to remove, and doesnt dent so easily as the original.
    The DS takes an 8.5mm gasket. I dont know about yours.
    Take the old one off and see if it is marked with the size.
    Failing that, write to/ring Pedro and ask him.
    I dont know why youd need to change the shower screen unless it was damaged.
  • krnjoejoe
    started a topic VBM Piccolo group head gasket size?
    Time to replace the group head gasket on my Lavetta/Piccolo.
    I realise it there is a 8mm and a 8.5mm size in the coffeeparts website.
    Which one should I buy?
    Also, is it advisable to change the shower screen as well?
    Any help would be greatly appreciated!
    Joe
