I would guess it screws on, but may be locktite or glued.
You could try and remove it with some multigrips, probably remove the lever first, or split it in two by taking a cuttoff disc on a dremel and carefully slicing up both sides. Either way you would probably be up for a new handle
So I guess make sure it is going to fit first.
