Re: Expobar Minore IV ?
Hmmmm... I prefered the shots before I tested the pressure, when the gauge on the Minore sat at about 9 bar. I shouldnt have dropped it down. Everything is tasting a little bit sour even though shots are tighter (lower pressure :
Also, should I start a new thread, or will someone be able to help me with my question about rotating the steam tap? I want to know if its possible to losen the tap, and rotate it to face the outlet upwards... Is it mounted to the front panel in a way that would prevent this, or does it seem possible?
EDIT: Just had a look... It seems the Synesso Steam wand ball may be very similar in size to that of the Minore III ;D That will make things much easier if everything else is doable
Nader
).Also, should I start a new thread, or will someone be able to help me with my question about rotating the steam tap? I want to know if its possible to losen the tap, and rotate it to face the outlet upwards... Is it mounted to the front panel in a way that would prevent this, or does it seem possible?
Nader
