Expobar Minore III - slow pressure loss...
  • Expobar Minore III - slow pressure loss...
    I have a slight issue with the new-to-me Minore III I just purchased from a well known Tamper man ;D - the pressure in the steam boiler (relatively) slowly drops off.
    It isnt a "problem" per se - but it is annoying because I cant figure out where the pressure is going to!
    I have the pressurestat set to 1.2bar and itll be there (say) when I start running a shot and drop back to just under a bar by the time I finish running the shot. Now - I know there is a HX loop in the steam boiler to pre-heat the brew-boiler water. This accounts for a pressure drop. Fine. But there is a steady pressure drop if I do nothing and just watch the pressure gauge... (And presumably if I dont watch the gauge too! :)
    I initially thought it would be the anti-vac valve suffering a small amount of leakage, but Ive given it a couple of taps with no real result.
    There is no obvious hissing, condensation etc etc.
    Is this normal for the thing? Anyone venture a guess as to where the steam goes?
    Like I said - not an actual problem, but it is annoying me that I cant see where the pressure goes!
    /Kevin
    Re: Expobar Minore III - slow pressure loss...
    Hi Kevin,
    Its a while since I last looked into a minore and I cant accurately recall the hydraulics, but I wonder if it could be a sticky solenoid (per favour of a touch of Adelaide scale) bleeding water destined for the group into the steam boiler instead?  :-?
    Merry Christmas
      Merry Christmas to you too, Chris!
      Thanks for that idea. Sounds plausible! Ill have a bit of a look after the silly day festivities..
      Just downloaded an exploded parts diagram and I never thought of that! From what it looks like - it seems that water might be able to leak from the steam boiler to the brew boiler inlet.. Which kind-of tallies with slow increase in brew pressure I see with it idle. Ill have some fun sleuthing :-?
      /Kevin
        the boiler is pressurestat controlled and so the element will turn on at 0.9bar and switch off at 1.2bar and turn back on again at 0.9bar and so on. Nothing wrong with the machine.
          The only reasons that may account for pressure loss during the coffee brew cycle are that the cold water entering the steam boiler HX can cause slight heat loss or a sticky water inlet valve on the steam boiler. Saying this have had a problem similar to this and it was the inlet valve not closing properly and water entering the boiler when the pump engaged. Hope this is helpful
          Cheers Gio
            The steam boiler certainly is, and that works perfectly. My "problem" is that the pressure just slowly falls as I watch. Far too quickly for static cooling of the boiler to explain. Probably something like 0.2 bar in 30 seconds...
            Originally posted by 46515F1F5557575E5D5C55320 link=1324763366/4#4 date=1324826776
            Cheers Gio
            Yup - the more Ive poured over the hydraulic diagram, the more Im convinced that the issue is the solenoid valve that regulates the steam boiler fill. From the hydraulic diagram - it shows the pump going straight to the brew boiler (via the HX in the steam boiler) with a switched Tee to the steam boiler. So whenever the pump runs, it pushes water into the brew boiler and sometimes into the steam boiler. If that valve is a bit dirty - I can see how youd get a slow bleed back to the brew circuit (and the OPV). Having said that, I also see that the solenoid is elsewhere shown with 3 ports... But the nett effect is that there is a single point where both circuits are potentially connected together.
            Anyway, it seems a plausible explanation. I took the E-61 group to bits last night for a clean/lube. Maybe tomorrow Ill drain the whole shebang and take the solenoid valve to bits.
            Thanks for disturbing your Christmas time to think about my problem!
            /Kevin
              Hi Kevin,
              I have seen this before on machines and I concur that the solenoid is the first place that Id start my investigations.
              Fiddly- but I suspect it will be a relatively routine fix.
              Good luck
                Originally posted by 7B4E4344706C4049494A4A2F0 link=1324763366/6#6 date=1324855240
                So I got bored :
                Not so much fiddly as wet! You need to (or rather - you effectively do) drain the boilers.
                The machine has only been used by me on rain water, and by Greg on some kind of bottled water. There was no scale (sorry Chris!)
                What was there was a spherical blob of stuff, which I rapidly identified as one of the resin beads from the filter in the tank!!
                Now I admit I did have the covers off the machine prior to starting this, but it only took 1 hour to do the job. And most of that was me trying to figure out how to drain the boilers without making a mess!
                All fixed!!! No slow pressure drop! Yay!
                (Until the next bit of gunk gets in there... )
                /Kevin
                  Ahh...man made stuff acting as Scale
                  Nice get Kevin and another win for the collective minds of CS. I am glad that all is now well.
                  FWIW, I dont have much time for the little resin filters. I have seen severe scale in a machine (Lindas) which receives the best of care and where the softener was soaked in salt water every fortnight as recommended. I think if your water is pre-treated anyway, you may as well bin it.
                    Could you share that link as I am having trouble finding one.
                    Maybe you or another CSer can help with my small problem though.
                    I am wanting to replace the group seal and did not notice the way the old one came out. I am assuming the flat surface goes in upwards with the slightly smaller and rounded edges to the group handle contact.
                    On that note of removing the shower screen for cleaning; any easy way apart from prying it out with a lever device?
                    Thanks in advance.
                    Kevo
                      Thanks in advance.
                      Kevo
                        Originally posted by 7F4A47407468444D4D4E4E2B0 link=1324763366/8#8 date=1324859419
                        I only have the choice of rainwater or dam water... The rainwater is so soft we have to warn visitors when they have a shower :
                        You will be pleased to know that as soon as I saw the wee little blighter, the first thing I thought was "right, this aint going to happen again!"... So the machine is basking in its naked water supply now
                        But now Im running out of coffee things to tinker with, so I might need to either go fishing or slash some grass :-/
                        /Kevin
                          OK - the diagram came from "disave.com.au"..  Since theyre not a sponsor linkage is somewhat forbidden.  You want the link to the "Office Leva" machine on the Expobar pages.
                          The seal?  Thats easy - the cross section of the seal is an upside down U.  The rounded bit goes up, not down!  If the seal doesnt have a "rounded" side, itll have a flat chamfer.  This sits against the showerscreen - the top of which is rounded over.
                          Ive never had a problem with levering E61 showerscreens, except when I came back from 6 months long service leave and the Wega in tea room had the shower screen glued on with tarry evil black goo...  I tend to take them off hot (be careful!) and use a stout teaspoon.  There is a tiny groove/dent near the bottom and I put the spoon in that and lever in very small bites.  If I had two teaspoons I reckon youd be able to just ease it down in one go.
                          You have to go slowly though, it only moves a couple of mm at a time.
                          /Kevin
                            Hi Kevin,
                            I just have bought myself a second hand Minore II. Installed it yesterday and I have the same thing happening! Steam pressure gauge slowly going down to 0.9 bar, red light goes on, back at 1.1 bar and slowly loosing it again. All at idle, the brew pressure gauge is indicating between 1 to 2 bar. Oh, and I have a slow water drip from the discharge pipe too, it seems to go up in the group as my basket has steam / water in it when left on the machine.
                            Just to confirm that you found the blob in the solenoid valve?
                            Cheers, Ernie
                            PS thanks for the link, exploded diagram downloaded.
                              Yup. Unfortunately for me, I had to repeat the exercise twice. The third time I got wise and had a go at flushing out the boiler > Havent had the issue since... The steam boiler seemed to be a reservoir for little filter beads > > >
                              The steam boiler will cycle up and down as it cools. On mine the cycle time was probably about 1 minute. It is now >5mins. The heater is on for maybe a couple of seconds to restore the pressure though..
                              The discharge pipe? You mean the e61 head or the wee little pipe that annoyingly curves down to the drip tray and catches the cleaning cloth 100% of the time when you wipe the tray?
                              If it is the latter - I believe that comes from the pump/opv junction in the hydraulic circuit. So if it drips constantly thatd be an indication of some pressure in there possibly from the steam boiler via the 3-way like I had.
                              Somewhat cramped to get at all this stuff, but relatively straight forward.
                              /Kevin
