Help for the e61 group head stuck (failed descaling?)
  • #16
    Re: Help for the e61 group head stuck (failed descaling?)
    Good solution. Could the smell youre smelling be the descaling fluid still contaminating the water?
    • #17
      Originally posted by 7F737075726B79721C0 link=1326110703/14#14 date=1326805006
      After I put everything back, I can smell the water from grouphead still have some old-tap-rusted smell.
      I wonder if its because I descaled it.
      Most likely it is the scale - everytime Ive done something like descale the kettle in the tea room it has a definite smell for a while. It goes away, which I guess means the fine scale which is still attached but somewhat loose eventually all disappears.
      So flushing a lot should do the trick. Since you had so much bother with blockages, seems to me that there was probably a lot of scale in there in the first place. I assume you descaled both the HX loop and the boiler? You need to flush both. The HX loop doesnt hold much volume so that shouldnt be too hard to flush..
      /Kevin
      • #18
        Thanks Mischa and Kevin.
        Probably you both are right.
        Because after read your post, I went back to do the flushing (another 20ish times).
        Then the smell is gone (horay!!), now I just need to sharp my brewing skill.
        Colin
