Acidic extraction
  • afit1551
    Re: Acidic extraction
    Tested the group temp it may be running a little cool but I dont think my method for measuring the temp was very accurate with a milk thermometer
    Now for a slight adjustment
    thanks everyone for the help
  • afit1551
    hmm, the machine was descaled a few months ago
  • coffeechris
    i was told not to put a descaler through the machine, which i did. the reason why is it can stay inside the boiler. the best netualizer although it takes the longest time is water. I was getting shots and and also steam that altered the taste of the coffee. I worked this out by tasting the water by itself....
  • afit1551
    I dont think citirc in the group is the issue because the following shots should have improved
    I didnt think about the temperature tho which will be the next thing to check
    thanks for the assistance
  • coffeechris
    Try a little test have make a cup of extracted waster from the machine (no coffee) also a small amount from your tap. see if there is a difference in the taste.
    From what you have written it sounds like there is still citric acid or what ever you used to flush your machine still in your machine.
  • Vinitasse
    oh... and I should have added... make sure the machine is running at the optimal temperature.... give it time to fully warm up before pulling a shot and if in doubt, check the temp of the water at the grouphead... a "workable" range would be somewhere in the range of 89-92 degrees. If the temp never gets above 89 the only coffee coming out of that machine will be acidic and tangy... at best
  • Vinitasse
    You may be underextracting, as in your shot is completing far too quickly... grind a bit finer, dose a bit more and lengthen the shot a bit... be careful though because if you drag it out too long you will end up with burnt, bitter, overextracted coffee in the cup
    Aim for an extraction of approx 30 seconds, give or take a few
    Good luck
  • afit1551
    Its a tangy acidic, I thought about the grind/grinder and cleaned the burs just in case and its still pouring fine
    thanks for your thoughts
  • LaughingAtFate
    acidic sour or acidic tangy?
    if its the sour sort of acidic, then its a case of the beans arent quite ground right for your parents machine
    if its the tangy sort, Well.. Possibly some difference in your machine process is dulling that? I dunno
  • afit1551
    started a topic Acidic extraction
    Acidic extraction
    Hi,
    Any ideas why shots pulled in my parents Bezzera domus are very acidic? when using the same beans in my brugnetti the shots have less acidity. So far I have done a thorough chemical flush, checked boiler for scales (was ok)
    thanks
