Giotto P+ group seal dropping out and correct dosing.
  • Giotto P+ group seal dropping out and correct dosing.
    Hi,
    have noticed in my GPP that the group seal is occasionally dropping out if I dont have the portafilter in.
    Does the rubber on these shrink or could it be another issue besides shrinkage/wear?
    Machine seems to be working properly otherwise...
    As an aside... do owners of this machine feel a small overdose works best for a double basket?
    Im leveling off and tamping to 12 pounds and it seems to be a bit muddy on top of the puck yet there is a mark from the showerscreen.
    Puck seems quite solid and I notice regularly that there is some channeling at the handle of the portafilter (always in the same spot though I have adjusted my filling with grinds to see if that was a cause).
    Re: Giotto P+ group seal dropping out and correct dosing.
    I thought it was 16 grams for double?
      not sure . I dont weigh my shots.
      Im more interested in what may be up with the group seal to be honest...
        A new seal is about $5.00 I would try that first.
        You are putting the seal in with the curved side uppermost arent you.
          the seal comes out with the showerscreen. I have not tried to separate them...
          yes it is in the correct way .
          Ill source a spare and go from there
