Faema e98 noises
  • artman
    Yep, or a bearing supplier. the local auto stores did not have anything small enough, the bearing supply shops have a heap of this stuff. or you can replace the whole valve, they are not expensive, I got bits previously from coffeeparts, great service from them.
  • Bill
    I got an o-ring of the correct size from an auto parts store.
  • saoye
    yep, that's the anti-vac. it works similar to the valve in a pressure cooker. If you're not sure of the o-ring size you can always take the valve with you. It's easy to remove...just make sure your machine is off and cool when you do!
  • MrT
    Here is a video of the hissing. I didn't have any luck getting one of the pump noise (seems to be intermittent). When I get one, I'll post it too.
    Faema e98 hissing noise - YouTube
  • MrT
    Cool. You guys are awesome.
    So, I've opened up the machine, and the hissing/spitting noise is coming from a valve at the top of the boiler. Now that you mention it, it looks very much like it would let air into the boiler, but not out (when I tap the little nipple bit at the top with a spanner it lets air out. Feels spring loaded or something too). I suspect this is the so-called anti vac value you people speak ok. Does what is says on the tin really... Where's the best place to get replacement parts? I don't want to take it to a repairer, as it looks like a simple job. Just an o-ring you think? Size?
    Ill try and get a video of the pump noise.
    Thanks!
  • Bill
    Agree with the others here that the hissing is most likely the anti-vac valve. Try replacing the o-ring.
    The point about the boiler cutting in and out noise - I assume you mean the clicking sound of the Sirai pressurestat. Yep, that clicking sound is normal.
    I'm not sure what you mean by the pump noise though.
  • artman
    I know what you mean, was just suggesting it could be as simple as a perished o-ring on the anti vac valve.
  • saoye
    Mate I know wat I'm trying to say but the fingers keep typing the wrong things! I've corrected to antivac valve. That's wat you get for writing in a forum at 2am in the morning.
  • artman
    Yep video would be helpful. The hissing sounds like the boiler system not sealing properly, most likely the o ring on the anti vac valve or build up as suggested.
  • saoye
    any chance of a video of the suspected problematic sounds? the whistle is possibly from the antivac valve not sealing properly. possibly due to some scale build-up or needs replacing.
  • MrT
    started a topic Faema e98 noises
    Faema e98 noises
    Hi everyone
    Just got my hands on a second hand e98 compact s1, and I'm just sorting out normal noises from potentially problematic ones.
    I noticed that on a very tight shot, the pump makes a pulsing noise rather than a continuous noise. Is this normal, or cause for concern? The water doesn't appear to fluctuate though...
    Also, the boiler cutting in and out is very clunky, but I assume this is part of it being industrious.
    Also, there is a faint hissing/whistle when the machine sits idle for a bit. Normal?
    Matt
