Can anyone suggest a better solution.
When I lift my brew lever upwards and just as you get towards the top of the movement there is a scraping of the internal parts.
Now when I strip down the section (see pic) What appears to happen is that the offset cam (part #11) open and shuts the spring loaded valves #9 and #25.
It is the scraping on these (#25) that is causing the problem.
I lubricate it with a food grade type grease (looks like vaseline) and the problem is solved for about 2-4 weeks.
Then it returns progressively after say 2 weeks.
The cam shaft (#11) is not bent or distorted.
Any suggestions as to the type of lubricant to use and is this normal or is there something else to consider??
thanks in advance
Sando
thanks in advance
Sando
