Rancillo S24
  • Rancillo S24
    Couple of questions if someone knows, S24 (tank model, vibe pump)
    1. If I loosen the bottom nut and drain the boiler, do I need to refill it manually or will the pump come back on, I realize the boiler holds 3.8 ltrs and the tank
    holds 2.5 ltrs so I would have to keep topping up the tank. (seems the low level water switch would cut out the pump)
    2. the plate says 0703 does that mean it is a 7th month 2003 model?
    C-
ID:	733827Click image for larger version
ID:	733827I hooked- up a gauge to the PF and it reads 12 bar as set from the factory, I am going to drop it to 9bar
    anyone ever see a OPV like this before? I read all I need to do is loosen the nut a little.
      Thats not it, the OPV is attached directly to the pump and looks exactly like a silvia OPV.
      You will need to add another copper washer to adjust the pressure down, or replace it with the newer adjustable silvia OPV
