Dosing problem with old Visacrem
  • Dosing problem with old Visacrem
    I am doing up an old Visacrem and after cranking it up the auto dose buttons are not doing what they should.
    They all turn on but not off.
    the red on/off button on the right works ok so I can pull a shot.
    does anyone know how to adjust the dose on this machine?
    I thought that would be worth trying first.
    If that doesn't work I am guessing the problem is either the flow meter or the PC board.
    Any ideas on how to test the flow meter?
    Cam
    Can anyone advise me on how to test the flow meter?
      found this thread, seems to be a bit of a fuss to test a flowmeter: Flowmeter test
      perhaps if you can source a similarly spec'd flowmeter from another machine and just install it and see if anything changes?
        Thanks for the idea of changing the flow meter noidle22.
        I have done this but still no success.
        I also found out how to test the flow meter with a multimeter. It seems ok.
        I am guessing it must me a PC board issue.
        I can't think what else it can be
