Expobar Minore (brewtus) handle is loose
  • Expobar Minore (brewtus) handle is loose
    Hey All,
    I recently pulled a couple of shots that backed-up my Minore.
    Almost straight after the shots backing-up I have started experiencing some issues with the handle/lever.
    When I pull the shot and put the lever back into the "off" position - it then raises itself back up about 45 degrees. Not so much the water starts running again.
    Is there an adjustment I might need to do to tighten this?
    Glyn
