In Brief
The Profitec Pro 500 has a heat exchanger for simultaneous delivery of coffee and steam and E61 group head for temperature stability and pre-infusion.
Pro 500 Highlights
The Pro 500 has a calibrated brew system for optimal brew water temperature even if left on for prolonged periods, non crush steam and water valves, a deep drip tray and easy access to the water tank via lifting the cup warmer tray.
Specification
- Heat exchanger system
- E61 brew group
- No-wear rotary valves
- Cool touch steam and hot water wands
- Boiler and pump pressure gauges
- 2L boiler
- Sirai pressurestat (Aus version - other regions may vary)
- 1400W Heating element
- Ulka EX5 vibration pump
- Water tank with coupling and 3L volume
- Sensor shuts off machine when low water volume
- Orange control lamp indicates low water
- Removable cup tray
- Weight 23.5kg (51.7lbs.)
- Dimensions: W x 302cm, D x 447cm, H x 393cm - without portafilter
- W x 302cm, D x 555cm, H x 393cm - with portafilter
- Voltage: 220V - 240V
