Last year I bought a nice PL60T from Jetblack Espresso.
it's been running great, so I thought I'd add some insulation to the boilers to help them heat up faster and maintain an even temperature more easily
SO I've used some proper foil-backed foam and wrapped each boiler, secured it all with S/S ties and it looks like a factory job.
Only thing is I've noticed it hunts down and back up to the preset temp (93') a lot more.
Now i'm assuming the PID controller has been calibrated to deal with the lost heat of having no insulation, and that's now causing some temperature hunting.
Are the PID controllers re-programmable at all?
Or am I better off just removing the insulation.
I've found I can trick the machine a little by setting the PID up to 95' when I switch it on
But when I start grinding I'll re-set it back at 93' and it comes back down to temp, and I pour my coffees.
Possibly the PID is calibrated properly to target 95' (as it was set out of the box) but the beans I'm using are blended/ roasted to be used at 93'
