Hi fellow coffee lovers,
I am new to this forum so I hope I am not asking something too obvious. I've done a fair bit of searching and tried a few things but haven't managed to crack this case.
Machine:
Giotto Rocket Premium - 2009 model
Tank model - not plumbed
Issue:
Other relevant information:
What I've done so far:
I have found that I can reliably reproduce the issue by simply pushing the reservoir in place. Once I lift it out again, leaving the white cup full of water, the light stops flashing. It seems like the reservoir being in place somehow increases the resistivity and triggers the low water sensor but I can't see how this would happen or what I can do to fix this.
I am very appreciative of any advice. I'm happy to take to a repairer if its not something fixable myself but we live in the sticks so I'd rather avoid a long drive or hefty postage costs if I can :-)
Thanks, Jonny
Machine:
Issue:
- When I turn my machine on from a cold start, it fills the boiler fine then begins to heat up. So far so good.
- After it has heated up it flashes the "low water" light and turns off the pump. Sometimes this happens during heat up and sometimes during the first brew.
- I've found that when I remove the water reservoir (half full) the light stops flashing and the machine heats up. When I put the reservoir back (half full) the light starts flashing again.
- I've been using the machine without a hiccup for the last 2 years using the same water supply. I'm using tank water. I've tried using filtered and non-filtered rain water.
- Every function on the machine appears to be working fine other than the low water sensor. i.e. if I earth the low water sensor the machine brews and steams like a dream.
- When I earth the white "low water" cable the light stops flashing. This seems to indicate that the low water cable is fine and the controller box is functioning as expected. I've brewed a few coffees with this cable earthed (making sure there was plenty of water in the reservoir and it was feeding through to the boiler) and it seemed to operate without any problems.
- I've checked the connectivity of the low water cable (white one) with the controller box. I read around 2-3ohms resistivity when measuring the probe on the side of the white reservoir cup to the connector on the controller box.
- I've checked the resistivity between earth on the power cable and the large probe inside the white reservoir cup and it reads around 1-2ohms.
- I've checked the resistivity between the large probe inside the white reservoir cup and the machine chassis and it reads around 2ohms.
- I've removed the white reservoir cup and rubbed the middle and side brass probes clean. I've removed the small brass valve inside the reservoir base (beneath the spring) and rubbed it clean then re-checked resistivity.
- I've descaled the machine twice.
- I've checked that all connectors and firmly plugged in to the controller box.
Thanks, Jonny
