Hello I recently purchased and rebuilt a la San Marco 85 16m one group machine. I really like the retro look of these machines and am happy with the end result, makes dam good coffee. It's a 1992 built machine and is solid. Has anyone else's had experience with these machines? Any input would be great. I will attempt to post some photos.
La San Marco
I recently worked on a 1995 model 2 group version of this machine. It ran well, no major problems. It had been sitting unused for a year or so, mainly as several parts had stopped working and the previous owner hadn't bothered getting it fixed.
The group solenoid coil had low resistance and was causing that circuits fuse to blow, vacuum breaker and pressure relief valve had both perished (easy and cheap generic replacement options) and both group seals had turned solid, needed some effort to get them out and they were like rocks. Both groups needed 0.8mm or so spacers installed for the group handles to lock in straight but this machine had seen use in a small cafe in it's earlier life.
All parts available from Coffee Parts at good prices.
The machines are well built, easy to work on and easy to use, I'm sure you will enjoy yours.
