Hiya,
So I've had my Bezzera Gea for ~3.5 years and am very happy with it. The only problem I have with it is that the top of the steam wand keeps coming loose and leaking steam. This thing has so much steam that the only real effect is that the milk takes longer to froth so I've been persevering for months this time, but I'm over it now. The 1st 2 times I took it to the repairer and had it serviced and fixed, but it is a 60min drive each way and (even worse) a week without coffee! You can see a gap in the picture at the top of the wand just above the knuckle, below the tap.
I would like to know why this keeps happening, but also how do I fix it? I've tried rotating the wand, but the "knuckle" at the top rotates with the wand which gets jammed up against the machine and can't turn any further. It looks like the SS pipe than forms the wand is screwed onto the moveable part that comes out of the knuckle, but I can't get a grip on the top part in order to unscrew the wand part - I've not been brave enough yet to get a spanner and just yank it. Hope that makes sense....
It's due for a service (and a thorough clean) so seeing as I am going to be pulling it apart anyway I thought I would do that as well. I'm pretty handy, and can usually get things put back together when I pull them apart. Is this something that a "handyman" should attempt, or should I just suck it up and spend the cash on a professional?
Thanks for your time
