Got new Giotto Rocket v3 (Hx machine). Only 2 weeks old. Vibrating pump model. Two pressure gauges, boiler pressure and pump pressure. This morning something went astray. Filled portafilter as usual, fitted to group head and switched on pump. Coffee took ages to come through, and then still only one drop at a time, pretty much for the whole 30ml. Pump gauge remained in sweet spot (approx 9 bar). NB I realise its pump pressure and not group head pressure.
My question. If I over filled, grind too fine, or tamped too hard, why doesn't the pump push out over 9 bar. My friends machine (Sunbeam or Breville DB) pumps up to 12-13 bar if the above factors are quite right. I know 9 bar is the sweet spot. Should I leave things as they are or should I try adjust the pump (or valve) to deliver more pressure. Ultimately I know I have to correct my technique.... Just wondering
Carlos
Carlos
