There are several comments on here that a PID in a HX (eg Giotto PP v3) is simply a digital pressurestat, and that makes sense to me.
But what I'm not sure of is how the PID actually works?
On my non-PID giotto the pressurestat cycles from roughly 0.9-1.3 bar. Does a PID just keep it at a much narrower range?
If it does, then wouldn't that lead to either reduced steam, or brew temp that's too hot?
To explain, if the PID is set to keep it at say 1.3 bar then you'll always have great steam, but your brew water coming through the HX will be quite hot.
And if the PID keeps the boiler at say 1.1 bar, them arguably your brew temp will be fine, but you're limiting your steam power.
Or have I completely misunderstood what the PID in a HX does?
Incidentally, I don't worry too much about flushing my brew water, but about half way through the shot I purge the steam for half a second, which drops the pressurestat below 0.9 bar and starts the boiler, so that when the shot has finished it's at 1.3 bar and I immediately start steaming my milk with maximum steam power.
Jonathon
Jonathon
