Giotto Water Tank Compatibility
  • Giotto Water Tank Compatibility
    Hello All
    Can anyone tell me if a water tank from a Giotto Premium will fit the Giotto Classic?
    Will depend on which variant you have.
    Earlier versions used a tank with internal probes to sense the presence of water. The final version of the classic switched to the coupling type tank which contains a brass probe and screw to sense water.
    A retrofit is possible to upgrade earlier versions but requires fabrication of the cradle and the installation of the coupling along with some alterations to wiring- so comes at a cost
