Hi Guys,
Just want to pick your brains. My 2010 expobar have been fantastic from the day I bought it 2nd (last year). The previous owner have not service it yet but have done regular backflushing with descale powders(he is a barista so I'm sure he knows what he is doing). Up to a week ago I notice that my machine is playing up abit,steamer have been decreasing in pressure and during pulling a shot the pressure bar generally stays stable at 9/10psi but now it's decreasing as I pull the shot some times slowly decreasing to 6psi.
Just abit of info on how I use the machine, I turn it on about 1 hour before I use it by setting it on a timer in the morning, pull the shot then flushing it everytime after a shot. If i know that I am going to drink another cuppa after work around 5pm then I will leave the machine on until then if not then I will turn it off. I will then backflush with a blind filter every week once. I make about 2 cuppa a day.
I've done some research and some say it's probably the boiler and some have said that if you change the water tank with cold water then the problem goes away. Which I have tried but I'm still not convince that it's the way to fixed the problem. I have also pull out the shower screen and rubber seal just making sure that it is not dried or damaged.
Does the machine needs servicing? If so anywhere you recommend in Sydney? What is the normal price for servicing?
Troy
Troy
