I'm eyeing up the Lelit PLT60T, but have a couple of questions you might be able to help with:
Here in NZ, the two models available are the PL60T, and the PL60 PLUS T (the latter seems to be referred to in Australia as the "V2".
The PLUS model is NZD$200 more expensive. As far as I can tell, the differences are the 300ml vs 250ml boiler for brewing, and the 58mm group head instead of the 57mm.
Are these features worth the extra cost? (Will there be any noticeable difference to the end result?). I don't have any other equipment which I'd share baskets/handles/tampers with.
Secondly, how long can I expect such a machine to last (given proper care)? In my mind, the extra cost is worth it over say the Breville BES920, because the Lelit will last much longer.
Thanks for your help!
