Gday all
When I turn on my coffee machine (5 year old Isomac Mondiale) the pump kicks in to fill the boiler, but it seems like the valve is stuck as the water is just cycling through back into the tank. If I leave it going it will usually kick in and fill the boiler after a while, maybe a minute or more. Rather than just leave it going, it usually kicks in a bit quicker if I turn it off and on a few times instead. The problem started after the machine sat without being used for a few weeks. Its back in daily use now.
My first thought was that maybe it was sticky from scale build up, although I don't know if they're susceptible to that. I've only ever done one descale about 3 years ago so I pulled out the mushroom to have a look.
There's very little scale on it, but a few lines here and there inside the group head. The gicleur screen thingo had some scale on it and was a bit stuck but not too bad.
From the look of the attached pics, is there any likelihood that scale could cause the valve issue? Is there any point in doing a descale? Or do I need to just buy a new valve? Or anything else to try?
Geoff
Geoff
