New Machine time
  • noidle22
    I got my Wega Mini Nova from a couple who moved here from Tasmania. The machine was at a technician somewhere in Tasmania, not sure where, and he replaced the pump, element and pressurestat to try and resolve the machine randomly turning off.
    The cause was a power relay on the control board, an $8 part. Hopefully the technician you are going to is not this guy. Can't imagine there's that many in Tasmania though. I don't know his name or business name but I would be careful if I were you. It might be worth shipping it up to Talk Coffee and having them do the work as you can be assured of the job getting done properly.
  • kaanage
    If you're at all handy, you can just unplug the machine (most important step!), take off the covers and then disconnect the lead to the boiler element and measure the resistance with a multimeter across the element terminals to check if it has blown. It should measure around 30 ohms
    Originally posted by ian66 View Post
    OK, I will make an appointment with a technician in Launceston - there appears to be a few there - and make a day trip and get a second opinion before I do anything rash
    Unless your tech is familiar with VBM and/or can source parts, I doubt there will be any more value in this approach.
    We can do it if you want to have it catch a boat.
  • ian66
  • chokkidog
    Sounds more like a faulty ..um.....'technician'. ;-)
    Thank you all for your responses. The current situation re my VBM is as follows:After losing hot water from the machine's hot water tap, I found a technician visiting my local town while servicing a commercial unit. He visited home and we turned the machine on, and just as it was warming up it tripped the fuse box. After resetting, the left hand light came on again, but now the machine will not heat up, the only thing it will do is turn on the pump when drawing a shot (now with cold water). The technician also advised me that VBM's are not made anymore and parts are hard to come by.
    Hi Ian,
    This brings us back to my earlier suggestion that he has not the the slightest inclination to repair your machine. Why? He doesn't have parts and can't be bothered sourcing them. A paid service call to do nothing is the easiest $$$ for him.
    This is routine and it's inexpensive.
  • brendogs
    Wow...
    They are certainly easy to come by. Probably the most accessible parts to purchase actually. Sounds to me like a faulty element that is going open circuit under load. It can be a slightly hands on job but it's definitely not worth throwing out! If you do throw it out let me know and I'll make sure I empty your bins that week
  • ian66
  • chokkidog
    Originally posted by Talk_Coffee View Post
    I'd bet my tech's left one
    Does Phil know about this wager???
    Poor Phil!!
    Just as well that you're right!! :-D :-D :-D
    .........probably!
    I honestly think it probably requires a hot water tap grommet, a check of the hydraulic circuit- perhaps a pump, possibly a descale and probably a service.
    I'd bet my tech's left one that it's routine and that it's worth repairing. If you decide not to, I'd suspect there will be regular clandestine slow passes of CS'ers waiting for you to put it on the nature strip.
  • TOK
    Hi,
    It appears that my much loved VBM is now terminal .... Ian
    Unlikely, except if you have been able to place a monetary fgure on the cost of a definitive repair and you consider it to more than the machine is worth to you...
    What's the tech explanation? If you have proceeded further than when you placed the other post, someone here may be able to make some suggestions.
    You may just have to use an infusion pot for a little bit while this is sorted, not the end of the world....espresso machines are not the be all and end all of good coffee.
  • ian66
    Good point, I discovered that with my old Silvia - I now have an under sink carbon filter system with an initial coconut fibre filter for water tanks - you tend to think that you have nothing to worry about withno Calcium or Chlorine concerns in rain water.
  • brendogs
    If you're in a remote area make sure you are using the correct filtration, I've seen some shocking outcomes from people who use unfiltered tank water.
  • blend52
    ...what is the difference/advantages between the Giotto Plus PID V3 and the Giotto Evoluzione V2? The other machine that interests me is the Isomac Mellennium Due.
    huge price range across those 3 machines ?
    If you want to maximise reliability,...minimise the amount of electronics in the machine !
    Hi,
    It appears that my much loved VBM is now terminal...
    Ian
    Hi Ian,
    I seriously doubt your machine is terminal.
    More likely, your service bloke either didn't know how to repair it or couldn't be bothered.
