Hey guys,
I'm new to the site, and love the community feel in what I've read so far!
So here's hoping you can help me out...
I have a Grimac 2 group compact. Recently had the right group buttons flash during extraction. Extraction happens fine, no problems with flow nor quality, but the flashing buttons meant the pull wouldn't stop. Even when using continuous flow, the button would flash.
I took this to mean the flowmeter needed replacing, which I confirmed with a tech that I bought some new group head seals from. Note that the original flowmeter is a non-LED type, however when I took it off the machine and dismantled it, the impeller seemed to be moving freely, so I assumed it was an electronic issue with the flowmeter. The new flowmeter I got has a LED indicator on the electronics.
So I have installed the new flowmeter and the LED on it pulses when there is water moving through it, however I still get the same symptoms at the buttons (flashing light, not cutting off at the end of an extraction). I changed the button pads around (swapped them between the two groups) and same issue on the same flowmeter. I even tested the continuity of the OUT wire from the flowmeter to the control box under the drip tray and that seems to be in tact.
Is there a diagnostic I can run using a multimeter regarding voltage/current output from the OUT terminal of the flowmeter? Or any diagnostic at all for that matter? This seems to be my missing link, as the flowmeter is powered up and moving freely, just seems not to be communicating with the button pad.
Any help would be greatly appreciated!
TIA.
TIA.
