My VBM Jnr is just over 1 year old and so I figured its time to inspect the steam and water valves cause my when my boiler heats up the steam valve leaks a bit. I brought the gasket kit for my steam and water valves which includes O-rings, and this red rubber cushion thing. I replaced a near failed O-ring which had a tear around the circumference on the steam valves. After this got replaced... no leaks and works better than before cause of all the food grade silicon I placed on the ball joint. Now it glides.
When I pulled apart the steam valve I couldn't find where this red rubber thing is. Does anyone know where this component should be during disassembling of the steam valves?
