I've had the machine for just under a year and I started noticing some water near the top largest bolt on the grouphead.
Picture here showing water marks: Imgur
The weird thing is the seal appears completely dry and fine when the machine is on and in use. Only after overnight in the morning do I notice some water drops around the bolt, after the machine's been off for 12+ hours. Is the top part of the grouphead under some sort of pressure while the machine's off?
No other leaks, everything else about the machine seems normal.
