To recap from the related thread I tagged onto, when unit is switched on the pump keeps running but no rise in gauge pressure or heating of boiler. There is no power to the element when checked with multimeter.
I have just opened up the head and everything is very clean with minimal corrosion and no scale.
Talk Coffee suggested "thermal switch, element or most likely a dead control board".
I'll be able to check the thermal switch next time I'm in my workshop. Is there any need to check the solenoid still or can that be ruled out? It had 230v across so has power but not sure about correctly functioning.
I will attach a photo of the control box. I read somewhere that some models require a modification or replacement. Is it possible to tell from this photo whether or not this should be replaced too?
Thanks for the help.
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[IMG]
