Hello again,
Acquired this Bezzera during this weekend and I've been searching the net ,found some leads however,of little use,hoping you people have dealt with these machines and can assist.
Seems this machine is (date of Manufacture) twenty six years old,unsure as to its history regarding it's use.
The previous owners were the business/contractors that removed the machine from it's last known cafe,and they thought it was unused for about five years,until I rescued it!
First thing I did was disconnect it's heating element and try a boiler fill,testing the external rotary pump.
Everything (pump and big blue filter ) was disconnected when first sighted,sorted that out (safely).
Reconnected the heating element(s) and run the machine as normal....all good ,all works as expected until I went to confirm group operation,nothing although the gauge indicated it was trying!
I switched everything off and disconnected power (10 amp/2000w),and let it all cool down,so further inspection was necessary.
Removed top access to group head,wire filter was choc-a-block with "gunge",cleared that then checked the small side access (group head) which seemed clear,some compressed air confirmed that.
Removed solenoid coil,checked resistance,Ok, then removed solenoid valve fitting which was clear as well.
Carefully reinstalled everything ,group head wise, connected it up again...bingo,everything worked perfectly as it was intended,great.
This leads me to the question,anyone know how the volumetric controls are customised/adjusted?
I've had a serious play with these controls and the volumes produced,according to cup size ,the actually produced flow is all "over the shop".
At least the buttons are working,further the pointer is turned ,produced more flow.Flow seems to be a timed flow rather then an actual measured volume.
Well here I am with a great little HX ,single group espresso machine,once the controls are sorted out I'll get stuck into the cosmetic clean up!
I need some kind person's helpful advice here,thank you.
Mick.
Mick.
